Vecchio 28 ottobre 17, 01:24   #1 (permalink)  Top
extrabrushless
L'avatar di extrabrushless
Data registr.: 19-10-2009
Residenza: Pisa
Ricaricare BOSCAM RX LCD5802
Buonasera.
Ho acquistato da poco un monitor per FPV, ovvero il boscam rx lcd5802.
Non so però come devo ricaricarlo. Ho letto il manuale e dice che la batteria interna è una 7.4V Li-POLYMER, ma come ingresso trovo stampato 12V.
Adesso mi chiedo, come posso caricarlo correttamente? Se lo volessi caricare con il caricabatterie, devo impostare Lipo o cos'altro? A quanti Volt lo devo mettere?
Grazie a chi mi saprà aiutare. Scivo qui per evitare errori e di conseguenza bruciarlo
Incollo le specifiche e allego il manuale in pdf.
Specification:
2 Built-in 5.8Ghz Dual diversity receiver automatically for best reception
2 Built-in 2CH 5.8Ghz AV output and 1CH AV input
2 Built-in high performance Li-POLYMER Battery: 2450mAH/7.4V
2 Work status OSD display : RSSI indication ; Battery indicator;Channel indication
2 A key to automatic signal search
2 Support Chinese and English menu
2 Size: 180mm x 120mm x 50mm(Note:Sunshield height:28mm)
2 Working Voltage: DC 7~16V
2 Power Consumption: 650 mA @12V
2 Battery charging current : 850mA @12V ( max )
2 Working temperature: -10°C~+ 65 °C
Features:
2 Built-in Dual Receiver Automatically for best reception Automatic Antenna Switching
2 Dual buffered AV outputs
2 Can receive 2 different channels at the same time
2 Not affect by 2.4GHz R/C Radios
2 AV Receiver with Diversity inputs
2 Small, light weight, durable
2 4 Bands and total 32 Channels
2 Built-in battery , easy to carry and outdoor use
2 A key to automatic signal search,Simple operation
2 Work status OSD display:Always be aware of the device working condition.
JACK:
4)DC/+12V: DC IN, +12 V power supply , the device operating current of 650 mA @ 12V,
built-in battery maximum charge current of 800 mA @ 12V; if the device is
working when charging , please pay attention to selecting the rated current
greater than 2A/12V charging equipment;
Files allegati
Tipo file: pdf SDLCD32_datasheet.pdf‎ (56,5 KB, 400 visite)
Auto: Losi 2.0EU elettrificata, Losi 3.0E, Lc Racing 1/14 buggy, Traxxas E-Revo 1.0
Aereo: kyosho calmato sport 60 8.5cc, jamara trainer 46 7.5cc, jamara dragonfly 15cc, cessna famous 182, yak 54, tuttala 1 metro ap.al.
extrabrushless non è collegato   Rispondi citando
