Vecchio 15 ottobre 17, 21:43   #441 (permalink)  Top
LONGFLYER
L'avatar di LONGFLYER
Data registr.: 06-09-2008
Originalmente inviato da 622090 Visualizza messaggio
Cercando qui e là:
https://www.rcgroups.com/forums/show...postcount=9329
purtroppo ho letto tutte le risposte e non sembra che abbiano trovato la soluzione.
Ho provato a disinstallare companion 2.2 e reinstallare niente.
Ho provato anche a fare le stesse cose con companion 2.1.9 e Taranis e ha funzionato perfettamente
Mah!!
Hai letto qui? OpenTX 2.2.0
Quinto punto:
Companion supports reading and writing Horus firmware when the radio is powered off and then connected to USB, using dfu-util and the libusb drivers installed by Zadig, exactly like for the Taranis. See the “Flashing your Taranis Radio” section in this manual. Companion can back up existing firmware (see note below in known issues) including the stock FrSky one (save as .bin), and can flash the FrSky DFU bootloader so that no other tool and/or driver swapping is needed. You might need to disable the “Check hardware compatibility” checkbox in the flashing dialog.
Saluti.
"If flying were the language of man,
soaring would be its poetry."
LONGFLYER non è collegato   Rispondi citando
