Vecchio 13 ottobre 17, 13:32   #1 (permalink)  Top
KAPPAWING182
Data registr.: 18-05-2011
Residenza: cagliari
icharger 308duo Impostazioni e valori
buongiorno a tutti !!
ho qualche problemino per impostare i valori di set up del balance del CB junsi
a pagina 17
chg END CURRENT e schermata successiva (scusate non riesco a caricare le immagini)
lipo balance set up
BALANCE DIFF
BALANCE SET POINT
BALANCE DONE DELAY.
invece a pag 18
BALANCE CHARGE END SET UP
1: The charger will stop balance charge if detects the
Balance condition is met, and the End Current
condition is invalid
2: The charger will stop balance charge if detects the End
Current condition is met, and the Balance condition is
invalid
3: The charger will stop balance charge if detects the End
Current condition or the Balance condition is met
4: The charger will stop balance charge if detects the End
Current condition and the Balance condition are met
..ma anche il paragrafo successivo ...non lo ho capito !!
Lipo advanced set up
RESTORE LOWEST VOLTAGE
RESTORE CHARGE TIME
RESTORE CHARGE CURRENT
Carico normalmente batt 4 s e 2S per buggy 1/8
Grazie di esistere!!!
Files allegati
Tipo file: pdf 308DUO_Manual_en.pdf‎ (1,60 MB, 166 visite)
KAPPAWING182 non รจ collegato   Rispondi citando
