Vecchio 20 settembre 17, 14:15   #10 (permalink)  Top
microcontrollorepic
L'avatar di microcontrollorepic
Data registr.: 18-07-2007
Residenza: milano
ciao,
questa è la risposta del fabbricante:
hello andrea
thanks for buying our 3D Printer.
the problem you mentioned regards leveling adjustment.
As the height of platform center to surroundings is inconsistent, which leads printed pieces will be too large or too small.
to solve this problem,pls go to our official website (Shenzhen Anycubic Technology Co.,Ltd) to refresh the firmware for Kossel Plus or you could directly check the firmware in SD card.
then decrease the value of 'DELTA_DIAGONAL_ROD' with 1~3
// Center-to-center distance of the holes in the diagonal push rods.
#define DELTA_DIAGONAL_ROD 271.5 // mm
other problems,pls feel free to contact.
regards
jutta
il firmware del link non lo carica mi da un errore.
modificando i valori del DELTA_DIAGONAL_ROD non cambia nulla.....
Flavio
SITO INTERNET:
Taglio cnc,https://www.rebasti.it/categoria-pro...B4q6Zc71GROXn4
microcontrollorepic non è collegato   Rispondi citando
