Vecchio 05 marzo 17, 23:30   #4 (permalink)  Top
carletttta
Data registr.: 14-06-2006
Originalmente inviato da stear147 Visualizza messaggio
grande carletta,ancora una volta mi soccorri......allora io seleziono il servo da regolare,seleziono start,poi pianino allineo il servo con l' altro,e fino qui c siamo,però dopo quando provo la corsa del servo regolato non ha più la corsa simmetrica ma mi risulta più scarsa dalla parte della regolazione,e non capisco la funzione init channel...
Questa è la procedura....
- Disconnect the linkages to the - as yet unmatched - servos, to avoid
them being subjected to severe forces during the adjustment
procedure.
- Set up one servo (generally the inboard one - SERVO 1) in
mechanical terms, using the transmitter if necessary; continue
adjusting until the centre point and the maximum end-points are
exactly as required.
- Now access the Servo-Matching menu and select the servo to be
matched. In our example this would be OUTPUT B and SERVO 2.
- Initialise OUTPUT B as described above.
- Move the cursor to START SERVOMATCHING → but do not press
the SET button at this stage!
- At the transmitter, move the aileron stick to the position to be
adjusted, then press the SET button.
- You can now release the aileron stick: the PowerBox maintains this
position. You now have both hands free, and can adjust the position
accurately with one hand, using buttons I and II, whilst checking the
length (matching) of the disconnected ball-link at the horn with the
other hand.
- Press the SET button again to conclude this adjustment.
- Complete the set-up procedure for the centre position and both
end-points before re-connecting the servo linkage.
- If you need to carry out further adjustments to another end-point or
centre position, move the aileron stick in the desired direction again,
and press the SET button again to start the procedure.
- Repeat the procedure with all the servos connected to the same
control surface
carletttta non è collegato   Rispondi citando
