Vecchio 17 novembre 16, 01:09   #2664 (permalink)  Top
lukappaseidue
L'avatar di lukappaseidue
Data registr.: 23-03-2015
Residenza: Catania
Aggiornamento Firmware Superflypacket 15/11/2016
Ciao a tutti raga,
segnalo l'uscita del nuovo pacchetto SUPERFLYFIRMWARE UFFICIALE
Qui il link per il download https://drive.google.com/drive/u/1/f...jlBT1haOGhRYTA
Di seguito riporto (copia/incolla) le istruzioni in inglese per l'aggiornamento (DA SEGUIRE RIGOROSAMENTE):
SuperFlyer is Official and Live
Hello, All.
I have some great news. The SuperFlyer is official. We also have a surprise for people who keep on asking if there's a way to fly above 250 meters, so stay tuned. Here is the link now, free for anyone to access:
**Please note that the 4.2.9 file is for the standard transmitter ONLY. If you have the advanced, you will not need to upgrade the TX. You need only upgrade FC and RX**
Video Tutorial:
Hubsan H501S firmware upgrade video tutorial (2 min 11 sec)
Hubsan H501S firmware transmitter upgrade video tutorial
Basically, there are three components to a full drone upgrade. You need to upgrade Flight Control (FC), Receiver (RX) and Transmitter (TX). Even though the numbers might vary from tutorial to tutorial, you can always see if the file begins with “FC”, “RX” or “TX/RC/HRC-FPV”. Also notice that there are two different upgrade tools: FC Upgrade Tool V2 and Upgrade Tool V2. The former is for the FC firmware upgrade and the latter is for RX and TX (FPV2 only). Keep this in mind.
If your computer does not automatically download the drivers from its connection with the drone, you may use the drivers located in the CH341SER driver file in the Drive. Do try just connecting the drone to the computer first, though.
You will need: an Android Mini USB and a Type A to Mini B USB.
Flight Control Upgrade:
1) Make sure you have an Android mini USB cord ready. Open the rear hatch of your drone and find the little port- connect your drone to the computer with this port and the cord (no need to connect battery to the drone).
2. Open up the HUBSAN FC UPGRADE TOOL V2.
3. As soon as the bottom of the upgrade tool shows 'connected', click “Open File”. Look for and select the file 'H501S-FC-V1.1.21.hbs'. Hit upgrade.
4. Once it reaches 100%, you will hear a USB unplugged sound from your computer, wait for it to automatically connect back again.
5. When it has connected again, click on show version and check whether it shows H501S-FC-V1.1.21.hbs.
RX Upgrade:
1) Make sure the transmitter and drone are off. You'll need to connect the transmitter to your computer with a Type Mini B USB.
2) Hold the Video key (FPV2 or the standard transmitter) or the Enter key (FPV1 or the deluxe transmitter), and pull the aileron stick to the bottom left corner of its socket. Hold both and switch on the transmitter.
3) The screen should now say "Upgrade RX Mode V2". If it does, initiate "Upgrade Tool V2" and go to the first step listed on the Program. Click "Connect"- and let the tool find your transmitter.
4) Once the tool has found your transmitter, you should see the screen say, "Upgrade RX Mode, Power on RX". Go ahead and connect the drone to its battery.
5) Go to the second step listed on your screen and select the file "H501S-RX-V1.2.12.hbs". Once you have done so, go ahead to step three and click upgrade.
These directions must be followed completely, or the upgrade may fail. If it does, start all the way from the beginning.
TX/Transmitter Upgrade:
1. Make sure the transmitter and drone are off. Connect your transmitter to your computer with a Type A to Mini B USB cable.
2. On your transmitter, hold down the Video key (FPV2 or the standard transmitter) or the Enter key (FPV1 or the deluxe transmitter), under the return home switch. Pull your aileron stick to the lower right hand corner and turn on your transmitter. The LED on your transmitter should start flashing red. The screen should still be black.
***Notice that TX upgrade protocol requires you to pull the elevator stick to the lower right hand corner, not left. This is the opposite of the RX upgrade***
3. Now, open 'Upgrade Tool V2'. Click “Connect” in the upgrade tool. It should say, “Found device on Com __”
4. Then, look for and select 'HRC-FPV2 V4.2.9' (standard transmitter ONLY) OR 'H906A-V1.1.3.hbs' (deluxe transmitter ONLY) in the upgrade tool.
5. Hit 'Upgrade'. After the upgrade is complete, the transmitter screen will say, upgrade finish.
After you upgrade any part of your drone, you MUST DO THE FOLLOWING:
First, calibrate your transmitter. Make sure your transmitter is switched off at first for this.
Transmitter Calibration Procedure:
1) If you fly in Mode 1, hold both sticks to the upper right hand corners and switch on the transmitter. If you fly in Mode 2, hold both sticks to the upper left hand corners and switch on the transmitter.
2) The screen should say "Calibrate Transmitter, Mode __". If this shows up, then pull the sticks up, down, left, right to their fullest extents- and do this twice, to be sure. When you have done this, long-press any trim on the transmitter- and it should beep.
3) If this does not happen, repeat the process after shutting down the transmitter again. If everything is successful, you should see the screen return to operating mode. Then, you will need to REBIND your transmitter to your quad.
Rebinding Procedure:
Make sure that both your drone and transmitter are handy, powered off.
1) Hold the photo button- and switch on the transmitter. The screen should say "System Initialize" then "Bind to Drone". If it just goes to normal operating mode, go ahead and try again.
2) Connect the drone to its battery and get it VERY CLOSE to your transmitter. Preferably you'll want to try fitting the right corner of the transmitter into the angle formed by the left drone arms.
The binding process will only work while the front two leds are alternatively flashing. If all the LEDs have started flashing, but the drone and transmitter have not "beeped" and initiated together, you'll have to try again.
If you are successful, the transmitter will "beep"- and you will see the screen FPV begin to start up, along with an additional pink "X4" satellite line above the green TX satellite line.
Rebinding has to be successful in order for you to begin normal flight operations again. Please follow all directions to the possible tee! Your drone should be good to go after.
Enjoy, everyone.
annegottagun is offline Send a private message to annegottagun Find More Posts by annegottagun
Reply With Quote Multi-Quote This Message Quick reply to this message
ATTENZIONE!
Questo pacchetto SUPERFLYPACKET, rispetto alla versione precedente che avevo postato tempo fa, ha reintrodotto la versione FC 1.1.21 poichè la versione precedente (1.1.22) è ancora in testing.
EVINDENZIO CHE LA VERSIONE FC 1.1.21 ha una funzione di failsafe (sicurezza) che spegne i motori se l'H501S si trova inclinato oltre 82° (sia in GPS che ALT HOLD) per almeno 1 secondo (tempo molto breve) mentre con la versione 1.1.22 questo tempo di attesa era stato portato a 5 secondi: il supporto tecnico, però, riferisce che al momento, nonostante questo failsafe sia pericoloso, la versione 1.1.21 è più stabile .... in ogni caso sul gruppo facebook c''è la versione FC 1.1.23 (CHE NON HO TESTATO), ma so che sta uscendo la versione 1.1.24 .......
lukappaseidue non è collegato   Rispondi citando
