| ATTENZIONE
è stato individuato un nuovo bug sull'ultima versione del firmware FC del quadricottero 1.1.21. In pratica appena il drone, in volo, si trova inclinato di almeno 82°, si disarmano automaticamente i motori, sia che stiate volando in GPS HOLD che ALT HOLD.
In ogni caso, pare che a giorni ci sarà una grossa novità da parte di HUBSAN, circa il rilascio di un firmware
questa è la comunicazione riporta sul noto forum
"Attention: Your prayers have been answered
To all free flyers in the forum here, I have a momentous announcement.
We have heard thy cries of frustration, observed thy tears of despair. Our good engineer amidst cases of repair bade me bring thee these words heralding great cheer:
We now have an official firmware configuration, or firmware "package" and two new releases of firmware in this particular package that will allow you to fly at a maximum height of 250 meters- and up to 800 meters with decent video feed (800 meters tested at a height of 150 meters).
I dub it the Super Flyer package. If you wanted the ultimate configuration for maxed out video and flight range, this is it. I will be releasing it when I get back from lunch, along with a new firmware upgrade instructional video starring none other than yours truly. It will be as detailed as possible, to help with the confusion. It really is not a very complicated process- just finicky. However once learned it really is quite easy. I'm a beginner and I learned it pretty much right away!
Paradox_Pete, Chris48, The_Kurd, and everyone else in here. I know you guys were asking about the differences between the firmwares, to try and get max range on video and flight. This is the all in one answer. This is even a version that you guys can DIY, for you coders out there.
No more needing to search for best possible configurations of firmware for range! Stay tuned. We will be mass messaging our customer support team in China to make sure they know about this as well, because we know you guys have been dying for some consistency"
