27 marzo 07, 12:11
#7 (permalink)
Top |
| Sospeso
Data registr.: 21-01-2005 Residenza: La Civile e Ospitale Emilia
| Citazione: |
Originalmente inviato da comet e della ventola che danno con il Kit tuttofibra di Movo , che mi sai dire? | http://www.warbirds-rc.com/Store/het6904.html Material: Carbon Filled Plastic, Aluminum - Outside Diameter: 72mm
- Inside Diameter: 69mm
- Weight: 56 grams - 68 grams (with cooling ring)
- Rotor: 4 bladed (68mm)
- Application: Medium to fast models
Note:- This fan is designed to be a drop in replacement for any EDF 480 application. Please note that the rotor and spinner cap is all one piece unlike the Wemotec Mini480 fan unit. The spinner cannot be removed or cut away from the rotor. The cooling ring included with each fan unit was specifically designed with the HET-RC Brushless Motors in mind, other makes and model motors built around a 400 can should fit but may require some addition work to attach.
