Vecchio 05 marzo 16, 00:24   #67 (permalink)  Top
LONGFLYER
L'avatar di LONGFLYER
Data registr.: 06-09-2008
Smile
Originalmente inviato da klamath Visualizza messaggio
• Industrial high resolution screen (480*272), readable outdoor
• All CNC gimbal with 6 ball bearings, accuracy hall sensor and extensible by stick ends
• Inbuilt GPS module
• Inbuilt wireless trainer system
• Inbuilt 6-axis sensors (3-axis gyro and 3-axis accelerator)
• Two types of aluminum panels (matt or texture)
• 16 channels (up to 32 channels)
• Audio speech function
• Full telemetry and real-time data logging
• Antenna detection and SWR warning
• Receiver match
• Newly designed internal RF module IXJT with lower latency and higher stability
• Inbuilt antenna as default, external antenna could be added (for internal RF module)
• External module bay
• Safe power switch with integrated strap base
• Two types of trainer ports
• MP3 player
• Haptic feedback
• NiMH batteries with inbuilt charging circuit
• 6 position encoder for easier flight modes switch
• FrSky FrTX operation system installed as default, Open source firmware supported
* Voice recognition might be applied on certain configuration later.
* FrSky reserves the right to change the hardware, software and specifications without notice.
mi gustano i gimbal al cnc
riguardo le funzioni vocale non ho capito se la horus avrà un sintetizzatore vocale?
Ciao, come mai hai dei dubbi a riguardo? Le caratteristiche riportano per l'appunto audio speech funtion. Piuttosto, noto la possibilità futuribile di un riconoscimento vocale ... interessante ed immagino anche un doveroso uso di microfono del tipo a stanghetta snodabile da porre davanti alla bocca (nel frattempo spero abbiano previsto un ingresso mic già dalle prime in uscita).
"If flying were the language of man,
soaring would be its poetry."
LONGFLYER non è collegato   Rispondi citando
