Discussione: Reset Hitec Eclipse 7
Vecchio 24 febbraio 16, 18:26   #5 (permalink)  Top
romoloman
Adv Moderator
L'avatar di romoloman
Data registr.: 15-08-2007
Dal manuale utente:
With the transmitter switched off, turn on your transmitter while pressing both of the two Edit keys(the two keys on the far left).
The model select (M.SEL) menu will be displayed.
2. Press the Up or Down arrow key until you get into the Reset (REST) menu.
This display has the word "REST" flashing on and off.
(If you're already in the setup menus, you can just press the Up or Down arrow key to get here.)
3. IF YOU ARE SURE YOU WANT TO RESET and clear out the current model memory, press both the +Increase and -Decrease Data keys at the same time. The transmitter will beep twice to indicate a successful reset.
4. Press the Up or Down arrow keys to get to another setup menu, or switch power off.
5. Switch power back on. You may now set up the details of your model in the
Edit mode.
CAUTION: WHEN YOU COMMAND RESET, YOU'LL ERASE THE MEMORY YOU'RE IN AND LOSE ANY PROGRAMMING YOU HAVE ENTERED. DON'T DO THIS UNLESS YOU ARE POSITIVE YOU WANT TO FLUSH OUT THAT MEMORY AND START FROM SCRATCH WITH THE FACTORY DEFAULT SETTING
Ovviamente da ripetere per tutti i modelli memorizzati
Grazie "TRANQUILLO"
FAI 15766
romoloman non รจ collegato   Rispondi citando
