Discussione: Setup Align 3gx
Vecchio 23 gennaio 16, 14:39   #1 (permalink)  Top
maricaro
Data registr.: 08-01-2009
Residenza: Villaurbana (OR)
No mi sono fermato prima di eseguire il setup del giro di coda. La radio è una Futaba T8J.
Ho trovato una faq su questo quesito.
Domanda: I installed V5.0 in the 3gx and it does not work, I have everything setup the right way and cannot get the Elevator Travel limit to work in the flight mode settings, I set the T-REX 800 up for 8 degrees cyclic. When I go into the travel limits I want 8 degrees cyclic so I dial it to 0 and it moves there but when I finish all the settings and go back to the mode you fly in, it has way too much cyclic about 14 degrees cannot get to stay at 8 degrees.
Risposta: It’s correct response. Because V5.0 enlarge the travel limit. The 8 degree only let system know the scale of servo and blade relation. V5.0 will detect the limit system need. So that it’s not looking like V4.0.
Se non ho interpretato male sembrerebbe corretto il comportamento del 3gx.
maricaro non è collegato   Rispondi citando
