Discussione: Scaler HG
Vecchio 02 luglio 15, 08:37   #1 (permalink)  Top
Robby Naish
L'avatar di Robby Naish
Data registr.: 16-10-2002
Scaler HG
Ciao a tutti,
non mi sembra nessuno ne abbia parlato, ma su un famoso ed ottimo sito Cinese di shopping ho trovato una serie di Scaler che non mi sembrano malaccio per meno di 200 euro spediti. Ma non sono esperto sugli Scaler, quindi mi riemtto a voi
HG P402 1/10 2.4G 4WD Wheel Drive Roadster Climbing Car
Description:
Item No.: HG-P402
Product Name: 1/10 2.4G-wheel-drive roadster climbing simulation
Remote Category: Proportional synchronous control system(gun control)
Motor: 540 High Power Brush Motors
Governor: 40A Electronics stepless 2 syncrebic of governor
Battery: 7.4v 1500-mAH lithium battery
Frequency: 2.4G HZ
Remote Distance: ≥100m
Speed: About 20 km/h
Action time: About 12mins
Charging time: About 3.5hours
Charger: 7.4V=800mAh
Controller Battery: 4*1.5V AA battery (Not included)
Protection function: 1-charge; 2-low pressure; 3-high temperature
Remark: The model both forward and backward, turn around and so on full scale synchronours control function.
Specification:
Car Size: 49×24.5×26cm(L*W*H)
Package Size: 61×26.5×30cm(L*W*H)
Wheelbase: 280mm/290mm/300mm(Ajustable: Factory standard: 290mm)
Wheel Track: 205mm
Wheel Diameter: R106mm
Weight: 3.9kg
Product Color: Silvery
Material: Hardware, Electronic, Plastic
Package Included:
1 × RC Car
1 × Transmiter
1 × Battery
1 × Charger
1 × Manual
1 × Kits
HG P401 1/10 2.4G 4WD Bigfoot Climbing Cars Remote Control Model
HG P601 1/10 2.4G 6WD RC Crawler RTR
Description:
motor:540 High Power Brush Motors
governor:40A electronics stepless speed regulator
battery:7.4V 1500mAh lithuum battery
frequency:2.4G HZ
RC distance: ≥100
RC time: about 12min
charger time: about 3.5 hours
charger: 7.4V=800mAh (included)
RC battery: 4x 1.5V AA battery(not included)
protect function:charger,low pressure,high temperature
specification:
car:64x24.5x26cm(LxWxH)
wheelbase: 280mm/290mm/300mm(adjustable;factory standard:290mm)
wheel track: 205mm theel diameter: R106mm
package size: 64x26.5x33cm(LxWxH)
product color: sliver
material: hardware,electronic,plastic
remote category: proportional synchronous control system(gun control)
speed: about 20km/h
Feature:
1:10 simulation of climbing dynamoelectric model car
front and back bridge use the independent link type hanging bridge system
a strong climbing capability and new structure
extensible 8x8/10x10 based on 6x6 on the vehecle underbody
there are 6 kingds of transmission ratio set
the central transverse motor power distribution system
track 3 position adjustable: 280mm/290mm/300mm
remote control channel reverse direction setting and shift function
package included:
1x HG P601 Climbing Car
1x Transmitter
1 set car parts
[YOUTUBE]https://www.youtube.com/watch?v=F2dr_0-eZtQ[/YOUTUBE]
Robby Naish non è collegato   Rispondi citando
