Vecchio 03 giugno 15, 08:56   #1 (permalink)  Top
Horus1969
Sospeso
Data registr.: 15-07-2006
Vendo LRP Blast TC2 Nuova!!!
Per cambio progetto, vendo LRP Blast TC2, la nuova versione della Blast TC, nuova ancora nella scatola. Ho soltanto aperto la busta con le istruzioni per studiarla un pochino...
Oltre a tutto quello che trovate nella scatola aggiungo come extra un set di molle Hard completo e i gommini interni per gli ammortizzatori in modo da evitare perdite di olio che ne comprometterebbero il corretto funzionamento.
Queste le caratteristiche del modello:
The S10 Blast TC 2 Clubracer features a specially developed 4WD chassis concept that fulfils all demands on a 1/10 4WD touring car. From the suspension to the drive, everything has been precisely adapted. Depending on the track layout, the suspension geometry can be completely adjusted.
The S10 Blast TC 2 Clubracer is a basis model ready for competition. It comes as a pre-mounted chassis without body shell, electronics and tyres.
Features
- Splashproof receiver box
- Completely mounted chassis
- Completely sealed drive train protects the gears against stones, dirt and dust
- Completely built with ball bearings
- CVD driveshafts front for constant power transmission and minimized losses
- 4 Big Bore oil filled shocks for perfect roadability on every surface
- Swaybars front and rear for improved cornering
- Steel differentials front and rear
- Fully adjustable onroad race suspension for perfect handling performance
- Left/right turnbuckles in front and rear
- Low maintenance and efficient universal drivetrain
- Reinforced front suspension
- Blue anodized aluminium motor mount
- Blue anodized aluminium suspension arm holder front and rear
- Easy to understand user manual including beginner and tuning guide
Per tutto chiedo 100 euro più spedizioni.
Per chi è di Roma previsto ritiro a mano.
Pagamento tramite postepay
Nome: Marco
Cognome: Mosca
Città: Roma
Horus1969 non è collegato
