Discussione: RegolatoriBL e Guard
Vecchio 02 marzo 07, 19:10   #4 (permalink)  Top
CantZ506
L'avatar di CantZ506
Data registr.: 10-04-2004
Residenza: Brescia
A quanto pare, non bilancia, ma fa scattare il cut-off se trova una cella più scarica delle altre.
When using balance discharge monitoring and protecting function (i.e. Plug the balance charge connector on battery pack into the balance discharge protecting socket on ESC, in this case , the ESC monitors not only the voltage of whole battery pack but also the voltage of each cell). For Li-xx battery,low / medium / high cut off voltage for each cell are: 2.6V/2.85V/3.1V. When the voltage of any cell in battery pack is lower than the cutoff threshold, the protecting program is activated.
Ciao, Piero.
