Discussione: Tutto su Phoenix RC
Vecchio 25 aprile 15, 09:54   #1868 (permalink)  Top
Filippo1784
Guest
Messaggi: n/a
Originalmente inviato da The Condor Visualizza messaggio
dal supporto ufficiale phoenix
If your throttle control is moving from one extreme to the other with no smooth change between then you may not have calibrated your throttle channel correctly.
Open the system > your transmitter menu and look at the orange bars on the display. Find the first bar that moves when you only move the throttle stick on your radio.
Does this bar move smoothly from one extent to the other as you move the throttle stick, and is it centered when the stick is in the centre of its travel?
If not, then you should recalibrate your radio by clicking the calibrate button, making absolutely sure that:
• You have your throttle stick centered when prompted, and not at the idle position
• You do not have your IDLE-UP/STUNT mode switches active at any time before/during the calibration process
If the throttle bar appears to be reacting correctly - i.e. moving smoothly from one extent to the other as you move the stick then you may just be experiencing the rotor governor which is fitted by default to many of the helicopters in Phoenix. The governor will attempt to keep a preset RPM whenever the throttle stick is above 25%, and is the most common way of flying an R/C helicopter model. To test if this is the case, fly a model which does not have a rotor governor such as the model > change > helicopters > electric > Blade CX2 model - does this fly as you would expect?
Davvero gentilissimo risolto tutto rapidamente numero 1.
  Rispondi citando
