Vecchio 19 aprile 15, 02:00   #11 (permalink)  Top
albo86
L'avatar di albo86
Data registr.: 02-07-2009
Residenza: trieste
Mentre la mia stampante è ferma in Belgio, quelli di HK si sono decisi a rilasciare un brevissimo FAQ relativo a questo prodotto e un paio di ore suddivise in 14 "puntate" di videoistruzioni sul tubo
What firmware is it running?
The printer is shipped with a Ramps 1.4 control system running preinstalled and tuned Marlin firmware.
What slicer or CAM software can it use?
The Marline/ramps board will work with a number of free
slicers or CAM programs such as Slic3r, Cura, Repeater host, Kisslicer, Skeinforrge and many more. We recommend Cura for its drag n drop ease of use and great slicing engine.
Resolution?
This is dependent on user defined settings of layer height, speed, and nozzle tip selected. The machines ability is X/Y=.0125mm (80 steps per mm) and Z=.000625 (1600 steps per mm) however layers thinner then .02mm or 20us is not recommended .100 is normal use
File Type?
The Preloaded marlin firmware accepts standard GCode
Options or dual heads?
The Turnigy Fabrikator was designed for adaption and main parts to be used by
a family of printers making future options kits such as a XL kit, dual heads
and accessories like .3~.5mm nozzles things to watch for.
What power does it run on?
The Printer is destined to take 100~220 volts A/C main in, the power supply
is a 12V 29A rating.
La probabilità che qualcosa accada è inversamente proporzionale alla sua desiderabilità.
albo86 non è collegato   Rispondi citando
