Per La Ennesima Volta!!! Non C'è Riduzione....con lo standard mode
nemmeno Con La 1.8.1!!!
GIA TESTATO con la 18 e la 9...!
"RF output power new test procedure, limit remains unchanged. The new procedure requires equipment that isnt currently readily available, especially for multichain transmitters."
4.3.1.1.2 Limit
The maximum RF output power for adaptive Frequency Hopping equipment shall be equal to or less than 20 dBm.
The maximum RF output power for non-adaptive Frequency Hopping equipment, shall be declared by the supplier. See
clause 5.3.1 m). The maximum RF output power for this equipment shall be equal to or less than the value declared by
the supplier. This declared value shall be equal to or less than 20 dBm.
This limit shall apply for any combination of power level and intended antenna assembly.
Ultima modifica di chrigui : 03 marzo 15 alle ore 11:13 |
