Discussione: Spektrum DX18
Vecchio 08 febbraio 15, 17:53   #1283 (permalink)  Top
rillo75
L'avatar di rillo75
Data registr.: 05-01-2008
Residenza: Bologna
AGGIORNAMENTO 1.08 AirWare:
New Features & Improvements
• The pre-flight checklist shows the name of the model on power-up. This allows
you to verify the right model is being started without having to go through the
complete list first.
• New trainer mode “FPV” added to allow head tracker inputs to be mapped to any
channel, with adjustable scaling and reversing. This mode enables easy
mapping of head tracker channels to receiver ports, while not affecting flight
controls.
• Add support for Flight Pack Capacity (mAh) and Receiver Pack Capacity (mAh)
sensors
• Add support for ESC sensor
• X-Plus channels are now able to be configured to generate warnings in 18-
channel systems, in addition to the normal channels previously available
• On the Model Copy utility, you are now able to select the Source model for
copying. It is no longer necessary to use Model Select first.
• When setting up a timer in a speaking radio, a 20-second alert is now available.
• You can now use the “wiggle” function to select analog inputs when entering a
“switch” option. Just move the appropriate switch or stick or slider and it will
select it automatically.
Corrections
• .AS3X Gains telemetry screen does not show when configured to not show.
• Sailplane AIL>RUD mix field “Sub Switch” is now exported properly.
• Heli gyro trim values are aligned properly for all flight modes
• Heli trim setup screen operates properly in tray radios
• Digital Switch Setup does not allow selection of Flight Mode switch if the Flight
Mode system is not configured.
• Trainer inputs are not allowed to exceed Absolute Travel settings.
• Corrected delay between tx voltage status announcements
• Telemetry screens now refer to Turbine rather than JetCat.
• Telemetry screens with trim displays now properly indicate centered status the
same as the main screen. • Sequencers and Gyros will now properly release a channel when being turned
off. Note that you must completely disable the gyro for the old channel name
and function to be fully restored. That is, you must set the Gain input (first
screen) to INH, click NEXT, then set the mix to INH > INH, then the switch to
INH. Only then will the channel be completely and properly freed up. For
sequencers you only need to set the output channel to INH.
....diffidate sempre dagli aeromodellisti da tastiera
http://www.aeromodellisti-aecibologna.it/
rillo75 non è collegato   Rispondi citando
