Discussione: Nuova Spektrum DX9
Vecchio 03 dicembre 14, 09:05   #11 (permalink)  Top
chrigui
L'avatar di chrigui
Data registr.: 21-07-2006
Residenza: Ferrara - Molinella
Version 1.06
Changes since 2014-April-18
New Features & Improvements
• Added AS3X Gain monitor functions for use with AR636, AR6335, and similar
AS3X receivers. When you enable telemetry option AS3X, you are able to see
gain status in real time, and adjust it with a trimmer. Note that this function
performs the following re-configurations in your radio:
o The F-Mode switch has its outputs set to the proper values for AS3X
operation. If you are using it for other purposes, you will need to
reconfigure those features to allow AS3X to use them.
o Mix 16 (DX10t and higher) is used to control AS3X gain.
o The selected channel is reconfigured for proper control. If you change the
channel, you will need to manually re-assign the old channel to its desired
purpose.
o Enables a screen “AS3X Gains” on the Function List to configure
parameters.
o Enables the AS3X telemetry gain monitor on the telemetry screens.
o If you are using a DX6, you can tweak the gains using the roller while on
the AS3X Gains configuration screen. If you are using a higher radio, you
can adjust at any time using the desired trimmer.
Corrections
• In Heli mode, Governor Trim function now works properly.
• Fixed Servo Travel problem for second Elevator in a 4-Servo swash heli.
• Improved translations in multiple languages
• When using a trimmer in 2- or 3-position mode, trimmers were acting as Flight
Mode trims. They are now operating in Common Mode
• Trim decrement tone was being controlled by the Switch Sounds setting
• Governor Trim on Heli Trim Setup screen is now properly adjustable
• If a radio is configured as a Wireless Trainer Master, if it were used as a wired
slave it would not function. This has been corrected.
Audio System Changes
• No changes
chrigui non è collegato   Rispondi citando
