Vecchio 05 novembre 14, 14:42   #7 (permalink)  Top
crazyflight79
Data registr.: 03-11-2014
Residenza: capua
Ottimo,comunque per fugare ogni dubbio,eccoti le specifiche tecniche....per la fine di novembre vorrei portarlo in volo
Technical data
- Wingspan: 1730mm (68.1in)
- Length: 1450mm (57.1 in)
- Flying weight: 4.2 - 4.8 kg
- Wing area: 46.6 dm2
- Wing loading: 80g/dm2
- Wing type: Naca airfoils
- Covering type: Genuine ORACOVER®
- Retract gear type: Air-retract With CNC Suspension Metal Struts (included)
- Spinner size: Plastic 70mm (included)
- Radio: 6 channel minimum (not included)
- Servo: 7 standard servo: 2 aileron; 1 elevator; 1 rudder; 1 steering nose; 1 retract; 1 throttle (not included)
- Recommended receiver battery: 4,8-6.0V 1200-2000mAh NiMH (not included)
- Servo mount: 21mm x 42 mm
- Propeller: suit with your engine
- Engine: .61-.91 / 2-stroke or .91 / 4 stroke glow engine (not included)
- Motor: brushless outrunner 1800-2000 W, 500 KV (not included)
- Gravity CG: 100 mm (7 in) Back from the leading edge of the wing, at the fuselage
- Control throw Ailerons: Low: 8mm up/down, 10% expo; High: 10mm up/down, 10% expo
- Control throw Elevators: Low: 8mm up/down, 12% expo; High: 10mm up/down, 12% expo
- Control throw Rudder: Low: 30mm right/left, 15% expo; High: 40mm right/left, 15% expo
- Experience level: Intermediate
RECOMMENDED MOTOR AND BATTERY SET UP
- Motor: Rimfire.60 (not included)
- Propeller: 15x6- 15x8 E APC (not included)
- Lipo cell: 6 cells / 4000 – 5500mAh (not included)
- Esc: 60-100A (not included)
crazyflight79 non è collegato   Rispondi citando
