Vecchio 21 maggio 14, 13:47   #1 (permalink)  Top
AlexBooo
L'avatar di AlexBooo
Data registr.: 27-02-2012
Gaui X5 + SK720 + Ricambi + Varie
Vendo il seguente materiale:
- Gaui X5 FES versione TT, meccanica, ESC YGE 100 LV, 3 x Hitec HS-7966HB, 1x Savox SH-1290MG, motore GUEC GM-601, Western Robotics Hercules Super HBEC MiniG2, pale SAB, palini Edge con vari upgrade (scatola di coda, asta di comando coda in carbonio, supporti coda in carbonio, carrello ad alta rigidità, protezione batteria, pignone e corona bevel). Prezzo richiesto 400 euro spedizione inclusa.
- Pacco ricambi (nuovi, imbustati) x Gaui X5 composto da:
1 x 208507 Motor Mount (fit M3 & M4 screws-Silver anodized) (208507) = £9.69
1 x 208913 120T Main Gears (Bevel) (208913) = £24.99
1 x 208906 Ball Links Pack (4.8mm) (208906) = £3.15
1 x 666167 GF Swash Cyclic Plate Tool (for X5 & X7) (666167) = £4.29
1 x 208368 C-Clip ( Set of 6 ) (208368) = £2.34
1 x 208790 16T Steel Pinion Gear Pack (Bevel ) (208790) = £10.91
2 x 208886 Bearing Pack
2 x 803729 Bearing Pack
1 x 208375 CF Tail Boom Support Rod Set
1 x 208704 Canopy Plate
1 x 208361 CNC Boom Clamps
1 x 208344 Canopy Posts
1 x 208404 Main Blade Linkage Rod
1 x 208401 Thread Rod for CCPM
1 x 217177 Tail Control Guide
1 x 208920 Torque Tube Front Gear Set
2 x 803730 Bearing Pack
1 x 805108 B.Pack
1 x 208367 Torque Tube Tail Boom Assembly
1 x 208705 X5 Fin and Tail Set
1 x 208504 FES CNC Main Grip Levers
1 x 208783 Stainless Ball Set
1 x 313081 Torque Tube Drive Gear Set
1 x 208381 Front drive gear set and Pulley Shaft with Steel Gear
1 x 208503 FES X5 Main Masts
1 x 208951 Tail Hub and Grip Assembly and Tail Output Shaft bevel gear set
1 x 313080 High Rigidity Brace Set
1 x H55036 550 Carbon Tail Control Rod Assembly
1 x EDGE 86mm Premium CF Tail Rotor Blades LE-86
1 x EDGE 523mm Premium CF Blades Flybarless Version LE-523FBL
1 x 208601 (GUEC GM-601) Brushless Motor
1 x Servo SH-1290MG
Prezzo richiesto 250 euro spedizione inclusa.
- 2 Centraline flybarless skookum robotics SK720 ad euro 110 l'una spedizione inclusa.
- 2 satelliti spektrum DSMX a 50 euro spedizione inclusa.
I ricambi son tutti nuovi. Il resto del materiale in buone condizioni e perfettamente funzionante.
Nome: Alessandro
Cognome: Vancheri
Città: Roma
AlexBooo non è collegato
