| Basher SaberTooth 1/8 Scale Truggy HK
non è sicuramente un Losi - Mugen - ecc
ma costa completo 190 euro ... ( disponibile in Europa )
un nuovo Truggy 1/8 da Hobbyking
non mettetemi in croce perchè il mezzo sarà poco robusto ecc ecc
( io ho due Losi ... )
a qualcuno potrebbe interessare
vi copio la descrizione :
New from Basher, the almost ready to run SaberTooth 1/8 Scale Truggy! Built on a rugged buggy platform with refinements to handle bigger tires and extra power, the SaberTooth a beast of a vehicle! This 1/8th scale grin inducing RC truggy is built to handle everything you throw at it! Dont think outside the box, SMASH through it while popping a wheelie and launching off a ramp!
The SaberTooth 1/8 Scale Truggy features a monster 4-cell capable brushless power system and puts all that power down through an all steel 4WD drive transmission. With big bore alloy shocks and heavy duty components, this truck can launch off almost anything and just keep on truckn!
The attention to detail on this truck is extraordinary. The engineers and designers at Basher underwent an extensive testing and development process to ensure no shortcuts were taken. Team Basher understands the importance of after sales support and offer a full range of spares for your battle scarred truck along with an awesome range of hop-up parts to upgrade your ride.
Features:
Almost Ready to Run - Just add your choice of battery and radio system
Powerful 1845KV Brushless Inrunner Motor (Waterproof)
100A Brushless ESC w/ Reverse (waterproof)
18Kg Heavy Duty Steering Servo (waterproof)
Full time 4WD
Steel front, center and rear sealed differentials
Hardened steel pinion gear
Heavy duty drive shafts
Hardened metal drive cups
Full ball bearings
3.5mm alloy chassis plate
Adjustable screw shock absorbers
Alloy oil filled big bore shock absorbers
Adjustable toe-in and toe-out
Adjustable camber and castor
Independent wishbone suspension
Shock tower support brace
Specs:
Length: 590mm
Width: 435mm
Height: 215mm
Ground Clearance: 43mm
Motor: 3674 Inrunner 1845Kv
ESC: 100A w/ Reverse Waterproof
Servo: High Torque Waterproof
Required:
2Ch Car Radio
Charger for Li-poly battery
2 x 2S 7.4V 4000mah LiPoly Packs
