ho trovato questo sul forum di heli x
domani provo sperando di non incasinare tutto.
Figured it out. In case this helps someone else with a Devo flashed with the Deviation 3.0.0: the firmware does not recognize the cable being plugged in automatically. Instead, you have to make a new model profile and chose PPM as your protocol, this will stop the radio and redirect all output over the PPM bus. Then you reboot the TX by using the Re-Init command in the menu, or just turn off/on the TX. Then everything works as it should in Heli-X. By the way, the "for JR" description in my PPM->USB only means that the cable is terminated with a 3.5mm mono jack, which is compatible with my Devo, with all the Spektrums and other transmitters. Naturally, all this stuff was written in the manual for the new firmware, which I did not read...
