Vecchio 02 gennaio 14, 01:37   #5 (permalink)  Top
greywall
L'avatar di greywall
Data registr.: 20-01-2013
Residenza: Foggia
Nuova release Deviation 4.0
E' stata appena rilasciata la nuova versione 4.0 del software Deviation.
Release Notes
Version 4.0.0
Created on Thursday, 19 December 2013 01:00 Last Updated on Wednesday, 01 January 2014 01:32 Written by PhracturedBlue Hits: 327
This is a major release of the Deviation firmware
IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!
Major Features:
◾Full support for the Devo12 screen
◾New fully configurable main-page layout
◾Limited functionality on Devo7e
Minor features:
◾Protocol-specific telemetry pages
◾New protocols
◾V202 (needs NRF24L01 module)
◾Tactic SLT (needs NRF24L01 module)
◾Hisky (needs NRF24L01 module)
◾USBHID (use transmitter as a PC joystick)
◾Support for 'master' trainer/buddy-box mode
◾Support for PPM inputs (FPV headset)
◾Support for RTC in Devo12
Incompatibility:
◾Switches are now numbered (e.g.GEAR0, GEAR1). Deviation will properly convert old models, but older versions of Deviation will not properly support models made for version 3.0 or newer
◾The channel scale is applied after the safety value. If safety is in use, make sure to check the values
◾The toggle icon locations have changed. Generally all models will need to be reconfigured to use the new icons. This was unintentional, but not easily rectified at this point.
◾If upgrading from a previous Deviation release and using an A7105 module (Flysky/Hubsan), the module will be initially disabled until you follow the directions here: DEVIATION Forum :: Topic: Flysky module users - You need to read this (1/1)
Qui sotto la pagina per il download
Deviation 4.0.0
Syma S107G, Merlin Tracer80, E-Flite Blade MCX2, E-Flite Blade mSR, E-Flite Blade Nano CP X, E-Flite Blade MCP X BL
greywall non รจ collegato   Rispondi citando
