Quindi considerando il mio caso
Blixer 1.1 con lipo 2650 3s e .. almeno 25C (credo)....
Motore = D2826-6 2200kv Outrunner Motor con 6x4e
Specs:
Rpm/V: 2200kv
Shaft: 3.17mm
Voltage: 2S~3S (7.4v to 11.1v)
Weight: 50g
Watts: 342w
Max Current: 34A
ESC: 40A
Suggested Prop: 7x4(2S) ~ 5x5 (3S)
Mounting Hole Bolt Circle: 16mm or 19mm
Turnigy nano-tech 2650mah 3S 35~70C Lipo Pack = 24,40 USD
Turnigy nano-tech 2650mah 3S 25~50C Lipo Pack = 17.26 USD
Turnigy 2650mAh 3S 40C Lipo Pack = 19,99 USD
ZIPPY Flightmax 2650mAh 3S1P 30C = 22,57 USD
ZIPPY Flightmax 2650mAh 3S1P 45C = 20,42 USD
ZIPPY Flightmax 2650mAh 3S1P 40C = 20,64 USD
Turnigy 2650mAh 3S 30C Lipo Pack = 18,03 USD
Quale prendereste?
Grazie a tutti
Ale
