Vecchio 28 novembre 13, 18:35   #1 (permalink)  Top
baccothe
L'avatar di baccothe
Data registr.: 10-12-2012
Residenza: roma
Sempre in rete ho trovato questo, ma...non riesco a capirlo
Codice:
//this programm will put out a PPM signal
//////////////////////CONFIGURATION///////////////////////////////
#define chanel_number 1  //set the number of chanels
#define default_servo_value 1500  //set the default servo value
#define PPM_FrLen 22500  //set the PPM frame length in microseconds (1ms = 1000µs)
#define PPM_PulseLen 300  //set the pulse length
#define onState 1  //set polarity of the pulses: 1 is positive, 0 is negative
#define sigPin 10  //set PPM signal output pin on the arduino
/*this array holds the servo values for the ppm signal
 change theese values in your code (usually servo values move between 1000 and 2000)*/
int ppm[chanel_number];
void setup(){
  //initiallize default ppm values
  for(int i=0; i<chanel_number; i++){
    ppm[i]= default_servo_value;
  pinMode(sigPin, OUTPUT);
  digitalWrite(sigPin, !onState);  //set the PPM signal pin to the default state (off)
  cli();
  TCCR1A = 0; // set entire TCCR1 register to 0
  TCCR1B = 0;
  OCR1A = 100;  // compare match register, change this
  TCCR1B |= (1 << WGM12);  // turn on CTC mode
  TCCR1B |= (1 << CS11);  // 8 prescaler: 0,5 microseconds at 16mhz
  TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
  sei();
void loop(){
  //put main code here
  static int val = 1;
  ppm[0] = ppm[0] + val;
  if(ppm[0] >= 2000){ val = -1; }
  if(ppm[0] <= 1000){ val = 1; }
  delay(10);
ISR(TIMER1_COMPA_vect){  //leave this alone
  static boolean state = true;
  TCNT1 = 0;
  if(state) {  //start pulse
    digitalWrite(sigPin, onState);
    OCR1A = PPM_PulseLen * 2;
    state = false;
  else{  //end pulse and calculate when to start the next pulse
    static byte cur_chan_numb;
    static unsigned int calc_rest;
    state = true;
    if(cur_chan_numb >= chanel_number){
      cur_chan_numb = 0;
      calc_rest = calc_rest + PPM_PulseLen;//
      OCR1A = (PPM_FrLen - calc_rest) * 2;
      calc_rest = 0;
    else{
      OCR1A = (ppm[cur_chan_numb] - PPM_PulseLen) * 2;
      calc_rest = calc_rest + ppm[cur_chan_numb];
      cur_chan_numb++;
baccothe non è collegato   Rispondi citando
