Niente di meglio che leggere note ufficiali (qui sotto riportate) prese dal suo manuale Download-FrSky]Download-FrSky Electronic Co., Ltd. Electronic Co., Ltd.
Buoni voli. Citazione: 2.2 Setting failsafe:
TFR6 support two selectable failsafe setting options, either use native failsafe position preset on the transmitter side, or
set failsafe on TFR6.
2.2.1 Use native failsafe position preset on the transmitter side:
If not disabling failsafe on the transmitter side, TFR6 will use native failsafe position preset on the transmitter side.
2.2.2 Set failsafe on TFR6 :
TFR6 supports failsafe function for all channels. Follow the steps below to set failsafe on TFR6:
1) Bind the receiver first, and disable failsafe on the transmitter side;
2) Set all transmitter controls to the desired failsafe position;
3) Press briefly the F/S button of the receiver, the GREEN LED of the receiver will flash twice, indicating the failsafe is set
up successfully.
If you do not need the failsafe function any more, just re-bind the receiver to set default failsafe mode. Hint: If not disabling failsafe on the transmitter side, TFR6 will use native failsafe position preset on the transmitter side. |
__________________ "If flying were the language of man,
soaring would be its poetry."
Ultima modifica di LONGFLYER : 23 novembre 13 alle ore 16:44 |
