Discussione: BEC : quale?
Vecchio 22 ottobre 13, 09:50   #18 (permalink)  Top
urgno
L'avatar di urgno
Data registr.: 20-06-2007
Residenza: dintorni di Venezia
altre info sul Keto
Sulla carta sembra ottimo nonostante il prezzo "popolare"
KETO HV BEC 12s 10A/20A V2 MT1818
One of the best BEC @ this moment.
Tested by Mikado and given a good review about reliability and endurance.
Measurement of the voltage stability of BECs KETO:
0A = 7,416 V
1A = 7.446 V
2A = 7,436 V
3A = 7.445 V
4A = 7.429 V
5A = 7,412 V
6A = 7.403 V
10A = 7,374 V
measured values ​​directly to the output without plug and cable resistance
± 0.1V core voltage may be different in other KETO HV BEC
Specification:
Continuous output current: 10 A max (with a slight air current)
Output current short: max 20A - about 4s - (the KETO it could be longer but not the small power plug in the receiver!)
Output cable: 2 pair of 0.35mm ² cable cross section and Graupner servo plug
Input cable: 1.5 mm ² cable cross section
Output voltage max. 5.0V, 5.5V, 6.0V, 7.4V, 8.4V (selectable by a jumper bar)
Precision of output voltage: 4.9V, 5.4V, 5.9V, 7.4V, 8.3V ± 0.1V
Input voltage range: 6V-50.4V (2-12S LiPo)
Dimensions: 62 x 26 x 22 mm
Quiescent Current: 60μA - 200μA
Weight: 40g
2x Prôtos Carbon Stretch FBL:MKS9660 / MKS9670 + BEASTX detti "i gemelli"
Acrobat Shark FBL +BEASTX detto "Emmenthal / Mucca"
urgno non è collegato   Rispondi citando
