Dal Manuale Assan
........omissis...........Use the rudder stick to increase/decrease limit Step 3: Adjust Second Limit (Low Servo Endpoint) Now, you are into the Adjust Second Limit (Low Servo Endpoint) configuration mode. Just like the First Limit (High Servo Endpoint) configuration mode, use your rudder stick to adjust the servo position for maximum tail pitch without binding.......omissis....
Chiaro?
__________________ Max flies with ===> DX8 - Sebart Wind 50 SE - Phoenix Model Tiger 40 - CopterX 450 SE V2 FBL - Jamara Siai Marchetti SF260- HK 600 "Alignizzato" FBL ------------------------- " Nel dubbio, giù tutto!" --------------------------- |
