Vecchio 10 settembre 13, 20:55   #5 (permalink)  Top
migliomerano
L'avatar di migliomerano
Data registr.: 10-05-2013
Residenza: Bolzano
Informazioni hobbyking
Ho trovato questo commento su hobbyking, a me pare lo stesso problema...
The speed controller turns the motor but only very slow and jerky, then it stops regardless of throttle settings. Please help!
Risposta di un utente:
try booting up the system with the throttle set to full what for beep then pull throttle back down to zero to set the throttle range. If this does not solve the issue check for a brake in the leads to the motor if one lead is disconnected the symptoms are jerky motor movement.
No man is rich enough to buy back his past.
Oscar Wilde
migliomerano non รจ collegato   Rispondi citando
