| User
Data registr.: 19-02-2013
| buddy code hobbyking TURNIGY BUGGY 1:16
CIAO RAGAZZI ECCO UN BEL PO' DI RICAMBI CON BUDDYPRICE PER TURNIGY RACING BUGGY 1:16 ...E ALTRO...ATTIVI PER 14 GIORNI DA OGGI!! Ball Bearing 10x15x4 (2pcs/Bag) - A2016T, A2030, A2031, A2032 and A2033 Female JST-XH <-> Male Polyquest 3S 10cm (5pcs/bag) Bearing Kit (7x4x2.5mm)(4Pcs/Bag) - 110BS, A2003, A2010, A2027, A2029 and A3007 Metal Drive Gear w/Shaft - A2003T, A2010, A2027, A2029 and A2035 Aluminum Lower Suspension Arm Bracket (front/rear) - A2003T, A2010 and A3007 Drive Shaft - 110BS, A2010 and A2003T Rear Lower Suspension Arm Mount - A2003T and A3007 (1pc) Rear Suspension Arm Pins - A2003T and A3007 (2pcs) Drive Gear/Univ.Joint - 110BS, A2003T, A2010, A2027, A2029, A2035 and A3007 Servo Saver Kit - 110BS, A2003, A2010, A2027, A2029 and A3007 E-clip (2.3x0.4mm)(10Pcs/Bag) - 110BS, A2003, A2010, A2016T, A2027, A2029 and A3007 Rear Outdrive Set - A2003T and A3007 (2pcs) Rear Diff.Box Complete - 110BS, A2003T, A2010, A2027, A2029 and A2035 Aluminum Front Shock Tower - A2003T and A3007 Slipper Set- 110BS, A2003T, A2010, A2027, A2029 and A2035 Rear Dogbone Set (2pcs) - A2003T, A2027, A2029 and A3007 Front Dogbone Set (2pcs) - A2003T, A2027, A2029 and A3007 Front Linkage Rod/Ball End Set (2pcs) - A2003, A2027, A2029 and A3007 Rear Ball End and Tie Rod - 110BS, A2003, A2010, A2027, A2029 and A3007 Servo Tie Rod - 110BS, A2003T, A2010, A2027, A2029 and A2035 Front C Bracket (left/right) - 110BS, A2003, A2010, A2027, A2029 and A3007 Front Lower Suspension Arms L/R (2pcs) - A2003, A2027, A2029 and A3007 HobbyKing 4-6min Epoxy Glue Turnigy nano-tech 460mah 2S 25~40C Lipo Pack Pin Set (7X1.5mm)(10Pcs/Bag) - 110Bs, A2027, A2029, A2031, A2032, A2033 and A2035 |
