Discussione: Spektrum DX18
Vecchio 13 giugno 13, 15:56   #1002 (permalink)  Top
mauro.ofx
L'avatar di mauro.ofx
Data registr.: 12-12-2006
Residenza: Albaredo (TV)
Originalmente inviato da chrigui Visualizza messaggio
posta il pdf con scritto cosa hanno fatto
Spektrum™ DX18 AirWare™
Change Log
Version 1.04C
5 June 2013
NOTICE
This version requires that you previously installed version 1.04 (8 April) into your
radio.
New Features & Improvements
• Enhancements to improve RF performance.
• Automatically disables France mode as it is no longer necessary.
Corrections
• Properly display RF PID code on the version detail screen.
SPECIAL INSTRUCTIONS:
Verify that your radio is currently at version 1.04. If it is not, download and install
version 1.04 (8 April 2013) first. Note that you need to export all your models prior to
installing version 1.04.
Once your radio is confirmed to be at version 1.04, install version 1.04C. Upon
completion of the update, go to the Serial Number screen (use NEXT several times
from System Settings). Highlight the version number and click the roller. This will
display the versions of several components. Verify that the RF PID is now properly
displayed as AE.
If you had to install version 1.04, now you may import your models again. You will
need to re-bind them.
NOTE: Do not revert to older versions after installing version 1.04C or higher!
mauro.ofx non è collegato   Rispondi citando
