Vecchio 12 gennaio 13, 14:09   #481 (permalink)  Top
puzarro
L'avatar di puzarro
Data registr.: 20-06-2007
Residenza: Milano
Originalmente inviato da broeselbroesel Visualizza messaggio
Kit Includes:
• 18T motor pulley (other pulley sizes available)
• 500 mm main blades
• 80 mm tail blades
Specifications:
• Main rotor diameter: 1136mm (with 500 mm blades)
• HPS Head (FBL Only)
• Main blade length: 470 to 500mm
• Tail rotor diameter: 226 mm
• Tail blade length: 80 mm
• Main shaft diameter: 10 mm
• Tail shaft diameter: 5 mm
• Spindle shaft diameter: 8 mm
• Gear Ratios 6.9-11 : 1
• Weight including electronics: 1900 g (excluding flight battery).
• 18T motor pulley included (other pulley sizes available)
•All pulleys are made for 6 mm motor shaft (5 mm motor shaft adapter included in kit)
Così però mi fai esaltare
Alex
puzarro non è collegato   Rispondi citando
