Originalmente inviato da Pogonaro Il gobbo però che io sappia non supera i 500 di pala , o no? Se così fosse fra il logo con pala 550 e questo c'è una bella differenza. |
Kit Includes:
18T motor pulley (other pulley sizes available)
500 mm main blades
80 mm tail blades
Specifications:
Main rotor diameter: 1136mm (with 500 mm blades)
HPS Head (FBL Only)
Main blade length: 470 to 500mm
Tail rotor diameter: 226 mm
Tail blade length: 80 mm
Main shaft diameter: 10 mm
Tail shaft diameter: 5 mm
Spindle shaft diameter: 8 mm
Gear Ratios 6.9-11 : 1
Weight including electronics: 1900 g (excluding flight battery).
18T motor pulley included (other pulley sizes available)
All pulleys are made for 6 mm motor shaft (5 mm motor shaft adapter included in kit)
