Vecchio 07 gennaio 13, 01:54   #3 (permalink)  Top
bandito83
L'avatar di bandito83
Data registr.: 29-06-2007
Residenza: napoli
Invia un messaggio via MSN a bandito83
ciao io questa radio la tenevo tempo fa e anche io persi tanto tempo per impostare il governor align se ti puo aiutare ho un post dove dice come si fa Setting up Align RCE6600 Governor using DX7 - YouTube questo è il video
e qua sta la spiegazione anche se in inglese di come si fa passo passo
I program my radio in this mode but the governor run with value rate -8% and ATV -100 +100.
I must set up a value ATV 0 +150 for run the governor with value ate +80% as it says the handbook Align
PROGRAMMING THE DX7
1. Go to the master menu. (Press down+select and power ON)
2. Scroll to Input Selct menu and set AUX2 to INH
3. Turn OFF and the turn ON the radio again.
4. Go to the programming menu. (Press down+select)
5. Scroll to PROG.MIX1 menu. We are going to setup here the desired headspeed for Normal mode. Set it to make it look like this:
AUX2> AUX2 ON -- if this says OFF, your flight mode switch is not in normal
RATE: +80% --- for 1882 rpm headspeed
0%
SW: F-NR
OFFSET: 0
You set your RATE % based on the headspeed you want for normal mode. Refer to the table chart that came with the GOV.
6. Scoll to PROG.MIX2 menu. We are going to setup here the desired headspeed for IDLE1 mode. Set it to make it look like this:
AUX2>AUX2 ON -- if this says OFF, your flight mode switch is not in IDLE1
Rate +90% -- for 2024 rpm headspeed
0%
SW:F-S12
OFFSET: 0
Again, you set your RATE% based on the headspeed you want for IDLE1.
7. Scroll to PROG.MIX3 menu. We are going to setup here the desired headspeed for IDLE2 mode. Set it to make it look like this:
AUX2>AUX2 ON -- if this says OFF, your flight mode switch is not in IDLE2
RATE: +10% -- NOT 100% for 2171 rpm headspeed
0%
SW:F-S2
OFFSET: 0
NOTE: IDLE2 uses the base number from IDLE1 and add it's own value to it. So 90% (from IDLE1) + 10% = 100%
8. Exit programming menu and verify that when you flick the AUX2 switch on your radio, you can turn ON (green) or turn OFF (red) the governor. Take note which way your switch turns the GOV ON/OFF. If necessary, you can reverse AUX2 from the reversing sw. on the radio.
messo cosi a me funzionava in ft mode cioè in modi di volo spero che ti sia stato d'aiuto
T rex600nitro Tsa 700 nitro platinum T rex450pro T-rex 450 pro Dfc Nine Eagle solo pro Nine Eagle free spirit Futaba T8fg 14 ch
bandito83 non è collegato   Rispondi citando
