Vecchio 03 dicembre 12, 20:07   #6 (permalink)  Top
Blue Eyes
Guest
Messaggi: n/a
Talking RICAMBI 1/16 Brushless 4WD Racing Buggy
Front Wheeldrive -110BS, A2003, A2027 and A2029
Front Upper Suspension Arm Holder - 110BS, A2003, A2027 and A2029
Diff.Pinion Gear S (3Pcs/Bag) - 110BS, A2003T, A2027, A2029 and A2035
E-clip (2.3x0.4mm)(10Pcs/Bag) - 110BS, A2003, A2016T, A2027 and A2029
Drive Gear w/Outdrive - 110BS, A2003T, A2027, A2029 and A2035
Front C Bracket (left/right) - 110BS, A2003, A2027, A2029 and A3007
Rear Dogbone Set (2pcs) - A2003T, A2027 and A2029
Front Shock Tower - 110BS, A2003, A2027, A2029 and A3007
Rear Outdrive Set - A2003T (2pcs)
Front Lower Suspension Arms L/R (2pcs) - A2003, A2027, A2029 and A3007
Diff.Pinion Gear B 2(long) and Outdrive - 110BS, A2003T, A2027, A2029 and A2035
Front Upper/Lower Suspension Arm Holder - 110BS, A2003T, A2027, A2029 and A2035
Steering Linkage Set Ball Cups w/Rods (2pcs) - A2003T, A2027, A2029 and A3007
Rear Wing Mount Set (complete) - A2003T and A3007
Front Steering arm (left/right) - 110BS, A2003, A2029 and A3007
Front Sway Bar Set - 110BS, A2003, A2027 and A2029
Pinion Gear B 1(Short) and Outdrive - 110BS, A2003T, A2027, A2029 and A2035
Rear Shock Tower - 110BS, A2003, A2027, A2029 and A3007
Front Linkage Rod/Ball End Set (2pcs) - A2003, A2027 and A2029
Rear Bearing Holder (left/right) - 110BS, A2003, A2027, A2029 and A3007
Slipper Set- 110BS, A2003T, A2027, A2029 and A2035
Servo Holder - 110BS, A2003T, A2027, A2029 and A2035
Hex Screw (M2.5x10mm)(10Pcs/bag) - 110BS, A2003T, A2027, A2029 and A2035
Screw Set (M3x7mm)(10pcs/Bag) - 110BS, A2003, A2027 and A2029
Screw Set (M2.5X6mm)(10Pcs/Bag) - 110BS, A2003T, A2027, A2029 and A2035
Grub Screw Set (M3x3mm)(10Pcs/Bag) - 110BS, A2003, A2027 and A2029
Hex Screw Set (M2.5x5mm)(10Pcs/Bag) - 110BS, A2003T, A2027, A2029 and A2035
Steering Linkage and Screws (M3x6mm) - 110BS, A2003, A2027 and A2029
Pin (18x2mm)(10Pcs/Bag) - 110BS, A2003, A2027 and A2029
Screw Set (M2.6x10mm) - 110BS, A2003, A2027 and A2029
Drive Shaft - 110BS and A2003T
Body Mount F/R - A2003T and A3007 (2pcs)
Servo Tie Rod - 110BS, A2003T, A2027, A2029 and A2035
Sway Bar Back Plate - 110BS, A2003, A2027, A2029 and A3007
Rear Sway Bar Set - 110BS, A2003, A2027 and A2029
  Rispondi citando
