Vecchio 17 novembre 12, 23:54   #1665 (permalink)  Top
romoloman
Adv Moderator
L'avatar di romoloman
Data registr.: 15-08-2007
Leggendo in giro pare che quel modulo soffra un po' di mal di pancia con 22.5ms di frame rate... provalo ad abbassare a 21 o 20..
Ti riporto un commento su HK:
"I installed this on a pcm10 ppm and had the loss of ailerons C2 right away, come and goes limited rotation range. Next I installed it in a er9x modified Turnigy channel maped as TAER, JR. Same issue. Next I used the er9x to decrease the frame rate from 22Ms to 20 and everything became solid! I'm now running 18 Ms and the 6 Ch menu option in er9x. So far everything is solid, full rotation ch 2, no cutting out. I only plan to use 4 Ch BNF and er9x can remap the sticks and channels, switches, ect, so I think I'm ok to fly it. Not very happy with the work around but I'm fortunate I have er9x because my JR can't use this module as it is now. I hope there will be a happy ending for all of us but until then I'll fly this way if the range is any good? That's the next test. I guess we're the unpaid beta testers? "
Mio commento personale... NO siete dei Beta tester paganti....
Grazie "TRANQUILLO"
FAI 15766
Ultima modifica di romoloman : 17 novembre 12 alle ore 23:58
romoloman non รจ collegato   Rispondi citando
