Vecchio 12 ottobre 12, 19:47   #3 (permalink)  Top
toio!!
Data registr.: 16-12-2006
PROP WOT RPM IDLE RPM
Top Flite Power Point 16X8 8,620 2160
Top Flite Power Point 18X8 7620 2160
Top Flite Power Point 18X10 6,890 2040
Top Flite Power Point 18X12 6270 2040
Top Flite Power Point 20X6-10 5660 2010
Top Flite Power Point 20X8 6300 1920
I'm sure RPM readings will increase as the engine continues to break-in.
PROP Static Thrust at WOT
Top Flite Power Point 16X8 13.68 lbs.
Top Flite Power Point 18X8 17.13 lbs.
Top Flite Power Point 18X10 14.0 lbs.
Top Flite Power Point 18X12 11.6 lbs.
Top Flite Power Point 20X8 17.85 lbs.
Top Flite Power Point 20X6-10 14.1 lbs.
Computed using the ThrustHP static thrust program
Questi sono, in ogni caso, dati ufficiali sulle performance del motore con eliche diverse (i tuoi dati sembrano eccessivi, soprattutto la 18x8 menz = pala larga)
toio!! non รจ collegato   Rispondi citando
