Vecchio 17 ottobre 06, 19:03   #3 (permalink)  Top
Temistocle
L'avatar di Temistocle
Data registr.: 07-07-2005
Residenza: Isola che non c'è (c'è, c'è)
le istruzioni
Riporto testualmente le istruzioni:
"Included as an accessory for your new receiver is an antenna bobbin.
This device was designed to allow the user the option of winding up to 18 inches of receiver antenna on it, this will shorten the antenna length that sticks out of the model.
NOTE: It is not mandatory that the bobbin be used.
DO NOT CUT WIRE
To use the antenna bobbin correctly.
1. Start winding the antenna wire onto the bobbin approximately 3-4 inches from the receiver.
2. Do not cross the wire on the bobbin. It should be smoothly wound in a spiral onto the bobbin. "
Temistocle non è collegato   Rispondi citando
