Discussione: Epa
Vecchio 10 ottobre 12, 15:07   #3 (permalink)  Top
Accetta77
L'avatar di Accetta77
Data registr.: 01-12-2006
Residenza: Milano
Ok, rettifico, ap. alare tra 800 e 850 e il resto in proporzione con 2 cm di tolleranza
3.1. Model
The model must be a scale or semi scale A/C fighter built between 1935 and 1945.
The model dimensions are determined as follow:
· Wingspan for single engine model max 850 mm
· Wingspan for double engine model max. 1000 mm
· Minimum wingspan for model is 800 mm
Recalculations of all other model dimensions are needful to be in the corresponding scale to the
chosen model wingspan scale. Max. 2 cm difference of these other dimensions comparing with the
corresponding wingspan scale will be tolerated.
It is not mandatory having the three-dimensional fuselage, it is allow having “flatling” fuselage. Its length is measured from the rear line to frontline of the fuselage, or to propeller (if the propeller exists).
No protruding devices may exist on the front leading edge of the wing, stabilizer and fin. It means, there are not allowed any parts of model in front of the leadings edges of the wing and tail planes of model.
Underlay of the leading edge of the wing and tail planes are not permitted. Lading edges covering by glass or textile slips will be tolerated. Application of the stream-cutting sandpaper strips is allowed.
Model should be build from EPP or similar mat. It is not allowed to coat surface of model or fill surface with putty
Model must look like original A/C including of camouflage, marking, emblems and so on. It is mandatory for pilots (competitors) support the visual aspects of model with the pictures or photographs of the A/C if there is some unclearness in the model appearance. Pilot (competitor) could not be a builder of the model.
www.77sterminalegni.it
Accetta77 non è collegato   Rispondi citando
