Vecchio 12 settembre 12, 23:05   #1 (permalink)  Top
tiger25
L'avatar di tiger25
Data registr.: 17-09-2008
Residenza: caserta
Motorizzazzione Vario Ab 212 elettrica
Salve devo costruire una fusoliera vario AB 212 e mia intenzione motorizzarla elettrica con i seguenti componenti:
Motore Turnigy HeliDrive SK3 Competition Series - 4962-480kv (700/.90 size heli)
Specs.
Turns: 12T
Voltage: 12S Lipoly
RPM/V: 480kv
Motor Poles: 10
Internal resistance: 0.023 Ohm
Max Loading: 90A
Max Power: 3800W
Shaft Diameter: 6mm
Shaft Length: 32mm
Screw Mounting Spacing: 25mm (M4x4)
Weight: 448g
Motor Plug: 4mm Bullet Connector
Regolatore TURNIGY K-Force 120A-HV OPTO V2 5-12S Brushless ESC
Specification:
Output: Continuous 120A, burst 180A up to 10 seconds.
Input Voltage: 5-12 cells lithium battery or 15-36 cells NIMH battery.
BEC: None.
Control Signal Transmission: Optically coupled system.
Max Speed;
2 Pole: 210,000rpm
6 Pole: 70,000rpm
12 pole: 35,000rpm
Size: 88mm (L) * 55mm (W) * 15mm (H).
Weight: 125g.
Cosa ne pensate
tiger25 non รจ collegato   Rispondi citando
