Vecchio 07 settembre 12, 20:00   #3 (permalink)  Top
rugrug
L'avatar di rugrug
Data registr.: 08-03-2010
Originalmente inviato da Guerinomaione Visualizza messaggio
Ciaoma tutti,
domani ricevo un t-rex250. Devo collegarci una ricevente spektrum AR6115e. Qualcuno può aiutarmi per favore?
mi sa che questa Rx nun bene va per elicottero ...
Product Specifications
Type:Microlite Park Flyer Receiver# of Channels:6ModulationSM2/DSMXBand:2.4GHzLength:1.11 in (28.2mm)Width:0.83 in (21mm)Height:0.39 in (10mm)Weight:0.14 oz (4.0g)Voltage Range:Input: 3.5–9.6V
Key Features
6-channel park flyer receiver
QuickConnect™
Red LED indicates number of holds
End-pin configuration
Overview
Spektrum’s 2.4GHz DSMX Technology gets even smaller with the AR6115e 6-channel DSMX Microlite Park Flyer Receiver with End Pins, which is ideal for small compact airframes. The AR6115e weighs less than 4.3 grams, making it a light 6-channel aircraft receiver option. Antenna locations give the AR6115e improved signal path diversity. The receiver also features a red LED that indicates the number of holds that have occurred since the receiver was last powered on. The AR6115e is compatible with all aircraft DSMX radios and module systems. It is designed for parkflyer use only.
** The AR6115e receiver is not compatible with the DX6 park flyer radio system.
