Vecchio 14 luglio 12, 16:40   #4 (permalink)  Top
rambodue
L'avatar di rambodue
Data registr.: 11-07-2004
scusami vado a sighiozzo ....
costa 0,75 dollari
This is the resonator used as the primary clock source for the mCP X MCU. It can crack or fall off in crashes.
Failure of the resonator will result in a mCP X that will not enter bind mode. The non physical symptoms are a single flash when the battery is connected. There may also be other flashes at long intervals from the internal watchdog timer.
MDM-1 FOX 2,74 - easy glider - asw 28 home made 1:4- Kyosho Caliber 30 - Blade mcpx - SST Racing Monster truck XP 1/9 - Align T-Rex 700X Dominator TOP COMBO
Radio FUtaba T14SG - Eclipse 7
rambodue non รจ collegato   Rispondi citando
