Mi sto cimentando anche io! Non sono del tutto certo che l'idea del pettine per i contatti sia la migliore (tenere fermo il tutto mentre programma e' un caos) ma il primo e' andato (bene) credo.
Codice:
~/simonk $ avrdude -c avrisp -P /dev/ttyUSB0 -b 19200 -p m8 -U flash:w:bs_nfet.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.12s
avrdude: Device signature = 0x1e9307
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "bs_nfet.hex"
avrdude: input file bs_nfet.hex auto detected as Intel Hex
avrdude: writing flash (8192 bytes):
Writing | ################################################## | 100% 4.80s
avrdude: 8192 bytes of flash written
avrdude: verifying flash memory against bs_nfet.hex:
avrdude: load data flash data from input file bs_nfet.hex:
avrdude: input file bs_nfet.hex contains 8192 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 14.52s
avrdude: verifying ...
avrdude: 8192 bytes of flash verified
avrdude: safemode: Fuses OK
avrdude done. Thank you.
blackman@altair:~/simonk $ Sarebbero da provare fin tanto che non sono tutti flashati per vedere come cambiano..
