E' questo?
Carbon-Z Yak 54 BNF
Key Features
Exceptionally strong and lightweight Carbon-Z airframe
High-performance prop optimized for precision and 3D flying
High-output 25-size brushless power system installed
E-flite 60A Pro brushless ESC installed
Spektrum 6-Channel AR600 DSMX receiver installed
Digital high-speed metal gear servos installed
4S 2800mAh 14.8V 30C Li-Po battery included
4S variable rate DC Li-Po balancing charger included
Low friction carbon rod hinges
Replaceable wings, stab, landing gear and control surfaces
Quickly disassembles for transport or storage in this box
Requires a full range DSM2/DSMX aircraft system (sold separately)
Overview
The Carbon-Z Yak 54 is a quantum leap in unlimited aircraft design that uses patent pending Carbon-Z construction. Carbon-Z is as strong and light as wood and gives the Yak 54 the kind of rigidity that allows it to fly with the energy and precision of a larger scale model. The brainchild of world aerobatic champion, Quique Somenzini, it comes out of the box equipped with a customized high-output brushless power system and digital high-speed servos. The combination of these high-performance components with the light weight and superb rigidity of the Carbon-Z airframe result in a 3D airplane with a 2:1 thrust-to-weight ratio that knows no limits.
Best of all, you can have this Bind-N-Fly® version flying in as little time as it takes to charge its battery and bind the receiver to a full-range DSM2/DSMX aircraft transmitter. To get the most from the Carbon-Z Yak 54, a programmable DSM2/DSMX aircraft transmitter with dual rates and exponential function is recommended.
Product Specifications
Wingspan: 48.0 in (1220mm)
Overall Length: 48.5 in (1230mm)
Wing Area: 525 sq in (34.0 sq dm)
Flying Weight: 3.75-3.80 lbs (1.70-1.73kg)
Motor Size: 25-size 1,000Kv Brushless Outrunner (included)
Radio: 6+ Channel Transmitter required (AR600 included)
Trim Scheme Colors: Red Pantone 185C, Blue Pantone 286C
CG (center of gravity): At wing tip, 6 inches (153mm) forward from the aileron trailing edge
Wing Loading: 16.2 oz/sq foot (50.1 grams/sq dm)
Prop Size: 12 x 5.25 (305 x 133mm) (included)
Spinner Size: 1.57 in (40mm)
Speed Control : 60-Amp Pro Switch-Mode BEC Brushless (included)
Recommended Battery: 2,800mAh 4S 14.8V LiPo (included)
Flaps: No
Retracts: No
Control Throw (Ailerons): Low: 30mm, High: 65-70mm up/down at aileron root
Control Throw (Elevator): Low: 15mm, High: 48-50mm up/down at counter balance leading edge
Control Throw (Rudder): Low: 45mm, High: 65mm right/left at counter balance leading edge
Approx. Flying Duration: 5 minutes
Charger: 4S variable rate DC Li-Po balancing charger (included)
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: Less than 1 Hour
Is Assembly Required: Yes
