Vecchio 08 maggio 12, 14:21   #1 (permalink)  Top
Crisx
L'avatar di Crisx
Data registr.: 19-09-2008
Residenza: FVG - (UD)
Motori Regolatore Centralina alimentazione Alewings
Ciao vendo un paio di cosette che non uso:
REGOLATORE TURNIGY TRUST 45 AMPERE:
Turnigy® TRUST SBEC ESCs have a very flexible and broadly capable MCU, able to run all types of brushless motors.The large heatsink and simple PCB layout make heat dissapation consistant, enabling the ESC to be run at its limit, without failure. The ESC is program-card and transmitter programmable with clear and easy to understand instructions included.
Default factory settings:
Brake: off
Battery: LiPo Auto Detect
Low Voltage: 3.2v (power down motor)
Spec.
Max Motor Current: 45A
Max BEC Current: 3A
BEC Voltage: 5.5v
LiPo: 2~6S
NiMH:5~12cells
Weight: 31grams
Programming Options.
Battery Type
Forward/Reverse
Soft Start
LV Setting (Ignore, Reduce Power, Stop Motor)
Timing (Auto, Med, High)
Switching (8,16kHz)
Factory Restore
NUOVO 20 euro
MOTORE TURNIGY AERODRIVE:
Spec.
Kv: 1050rpm/v
Operating Current: 6A ~ 20A
Peak Current: 23A
Weight: 73g
Dimensions: 27.6 x 36mm
Shaft Size: 3.175mm
Kit includes full accessories, including gold bullet connectors, prop saver, mount, spare rubber rings, shrink tube and screws.
Performance Data
Voltage Current Prop Thrust
11.1V 15.5A 9050 900g
11.1V 18.6A 1047 1090g
11.1V 19.5A 1060 1020g
NUOVO 18 euro
MOTORE HACKER A20-20l
Hovering.it
USATO 10 euro
CENTRALINA ALIMENTAZIONE ALEWINGS
Centralina ESC per alimentazione RX! un ingresso per batterie LIPO 2s e due uscite stabilizzate!Maggiori informazioni sul sito alewings!
50 euro
Nome: Cristiano
Cognome: Decorte
Città: UD
Crisx non è collegato   Rispondi citando
