| scritto da kaboc6Magari è un problema di timing del regolatore e bisognerebbe cambiarlo, ma non so bene la procedura con quell'esc.
Fatti dare il manuale da dove l'hai preso.
Configurable parameters:
There are 8 types of items can be programed:
1. Brake Type: Off / Soft / Hard, default is Off.
Soft brake, less forceful and brake time is longer.
Hard brake, more forceful and brake time is shorter.
2. Advance Timing: Low / Middle / High, default is Middle.
Low advance, is for high inductance and low KV value motors.
High advance, is for low inductance and high KV value motors.
For some high Kv motors, if it shakes while rotating in high speed, then High mode is recommended.
3. Start Mode: Fast / Soft / Very Soft, default is Fast.
Fast is preferred for fixed wing aircrafts.
Soft and Very Soft is suitable for helicopters
4. Cut Off type: Reduce power / Shut down, default is Reduce power.
5. Throttle Curve: Curve 1 / Curve 2 / Curve 3, default is Curve 1.
6. Numbers of Lipo Cells: Auto detect / 2 cells / 3 cells / N cells, default is Auto detect.
7. Cut off threshold: Low (2.8v) / Mid (3.0v) / High (3.2v), default is Mid
8. Motor Rotation: Forward / Reverse, default is Forward.
1. Entering Program Mode:
First of all, please un-plug the tail motor and remove the main blade before entering program mode for safety reason.
Steps:
A. Move throttle stick to bottom,
B. Switch on the transmitter,
C. Connect battery pack to ESC,
D. Move the throttle stick to top when the LED of ESC turns on.
E. Waiting for about 4 seconds, a special tone like ♪i3i3shoud be emitted from main motor, which means program mode is entered.
2. Select Programmable Items:
After entering program mode, you will hear 9 tones in loop in the following sequence.
If you move the throttle stick to bottom within 2 seconds after one kind of tone, this item will be selected.
Item
Tone
Mode
1
Be-
1 short tone
Brake
2
Be-be-
2 short tone
Timing
3
Be-be-be
3 short tone
Startup mode
4
Be-be-be-be
4 short tone
Cutoff mode
5
Be-----
1 long tone
Throttle curve
6
Be-----be-
1 long 1 short
No. of lipo cells
7
Be-----be-be
1 long 2 short
Cutoff threshold
8
Be-----be-be-be
1 long 3 short
Motor Rotation reverse
9
Be-----be-----be-----
3 long tone
Exit program mode
3. Set Item Value
After entering the item, you will hear several tones in loop, set the value matching to a tone by moving the throttle stick to top within 2 seconds when you hear the tone, then you will hear special tone like ♪5656. It means the value is set and saved.
Wait for 3 seconds, you will go back to step 2 (select programmable items).
Tone
Value
Be-
1 tone
Be-be
2 tone
Be-be-be
3 tone
Be-be--be--be
N tone
1. Brake
Off
Soft
Hard
2. Timing
Low
Mid
High
3. Start Mode
Fast
Soft
Very Soft
4. Cutoff Mode
Reduce power
Shut down
5. Throttle Curve
Curve 1
Curve 2
Curve 3
6. No. of Cells
Auto detect
2 cells
3 cells
N cells
7. Cutoff Threshold
Low (2.8v)
Mid (3.0V)
High (3.2v)
8. Motor Rotation
Forward
Reverse
4. Exit Program
There are 2 ways to exit program mode:
1. In Step 2, after 3 long tone (the item #9), please move throttle stick to the bottom position within 2 seconds.
2. In Step 3, after special tone ♪5656, please move throttle stick to the bottom position within 2 seconds.
scusate l'inserimento di tutta la programmazione dell'esc ma forse in futuro potra' tornare utile a qualcuno; se ho capito bene al punto 2 il timing è programmato su middle e poi se ho tradotto bene c'è scritto che per alcuni motori al alta kv, se scuote durante la rotazione ad alta velocita', la modalita' hight è raccomandata!!!! ho capito bene ???? potrebbe essere il mio caso??? oggi provo, anche se entrare in programmazione mi fa un po' paura!!!(tanto così non funziona)!!!
Ultima modifica di ric-riccardo : 13 aprile 12 alle ore 13:24 |
