Originalmente inviato da I-MACS fantastico!
dimenticavo...preso dal tuo articolo.. {The upper flow is faster and from Bernoulli's equation the pressure is lower. The difference in pressure across the airfoil produces the lift.} As we have seen in Experiment #1, this part of the theory is correct. In fact, this theory is very appealing because many parts of the theory are correct. In our discussions on pressure-area integration to determine the force on a body immersed in a fluid, we mentioned that if we know the velocity, we can obtain the pressure and determine the force. The problem with the "Equal Transit" theory is that it attempts to provide us with the velocity based on a non-physical assumption as discussed above. |
eh si, questo complica un pò le cose.
Ha ragione la teoria dell'azione e reazione o quella della differenza di pressione?
ps : Non so se ci avete badato, a quante volte la NASA ha modificato il tiro in queste sue presentazioni "educational".
