Vecchio 02 aprile 12, 09:58   #13089 (permalink)  Top
matrixFLYER
L'avatar di matrixFLYER
Data registr.: 04-11-2011
Non so se era stato già segnalato, ma ho trovato un commento interessante su hobbyking in merito ad un servo economico per l'mcpx
Questa è la pagina del servo
HobbyKing R/C Hobby Store : 2.4Ghz SuperMicro Systems - Single Linear Servo
dove c'è il seguente commento nelle discussioni:
It does work on mcpx i have done so for some time,plugs stright in. The trick is to get an old credit card and trace the original base of the spectrum linear servo plate, cut it out and hot glue this sevro to it.If you want to go further you could put little screws in it that you probably have in your parts draws and fasten to this adapter plate which with original screw goes back into orignial position. worked well for me.although it does have a little more play in the shaft up and down but not really noticable to me in flight. will be getting more, as i burnt one out my own fault after a crash i broke a wire resoldered but left to much wire open near joint and unfortunaly next hard hit managed to bring wires together and start to smoke up. I'm not up to hard 3d just yet but can flips ok and get good forward flights and inverted hover. Good luck buy 3 for the price of one.
In breve pare sia utilizzabile quel servo con un po' di fai da te, sagomando un pezzo di carta di credito per esempio a forma della base del servo originale.
P.S. Certo che di questo clone di mcpx non si è saputo più nulla! Sparito! Magari i servi erano identici
_____matrixFLYER_____
matrixFLYER non è collegato   Rispondi citando
