Vecchio 31 marzo 12, 21:46   #9 (permalink)  Top
giava76
L'avatar di giava76
Data registr.: 24-09-2007
Residenza: Padulle
Le differenze tra Jeti e Hacker-Jeti (che dichiaratamente escono da Jeti come fabbrica) sono il software cioè ci sono più programmazioni, la gestione delle temperature, ed alcune piccole differenze hardware.
Qui si chiaccherava a proposito
Last week I posted on specials I am running on the Mega/Hacker motors and Jeti/Master controllers.
As the controllers are made in the same factory I was challenged on the small price premium of the Hacker Master over the Jeti controllers.
After further investigation I am satisfied the Hacker Master controllers justify their price. More significantly I do not believe they should be compared to the current Jeti controllers but rather to the Schulze controllers.
The Master controllers carry class leading feature in their software and hardware. These features are unique to Hacker Master controllers.
The software
Hacker explicitly acknowledges the joint design and production effort between Hacker and Jeti on the new controllers.
The software is the first and most significant difference between the Jeti and Master controllers.
Developed to Hacker’s specifications the software provides 4 timing options – #1 is optimized for Hacker motors. The other 3 steps ensure the Master controllers can be optimized for the widest possible range of brushless motors.
For the Master 40-3P and up, variable operating frequencies maximise the efficiency of the controller/motor packages under different throttle/load combinations
Jeti controllers have fixed timing and fixed operating frequencies.
The hardware
New hardware protects the controller from electrical spikes, achieves high levels of flexibility and allows control to be maintained in the case of overheating
To improve reliability and performance of the Master controller Hacker specified a controller carrying circutry to cut voltage spikes reaching the controller.
These spikes are worst at part throttle. They heat the FETs and increase internal resistance thereby reducing efficiency. They can also damage the controller.
The Jeti does not carry this componentry.
To provide maximum flexibility the Master controller’s voltage cutoffs were designed to ensure they respond smoothly and reliably with 6 and 7 cell packs.
Jeti's controlers operate best at 7 cells plus.
Also, under thermal overload the Master controllers enter partial shutdown. This enables the model to be flown to a safe landing.
All up these changes have produced controllers who matched with the Hacker motors meet or exceed the standard set by the previous class leaders.
The Master 99 for instance has an on resistance of .7 milliohms – the same as the Schulze 88/105. The 99-3p copes with up to 24 cells the 88/105 with 17. Uner static load the Master 99 has endured 130amps loads for 10 seconds – typical of F5B workloads - without signs of distress. This is the equivalent of the overload rating for the Schulze 105
Rainer uses a Master 77 in his own Hotliner and has subjected it to 10 second runs in excess of 120+ amps without problems. This performance is comparable to the f80 / f102
Best of all there are new low resistance FAI controllers in the pipeline.
Finally
Using the 70 amp controller for direct comaprison
the Jeti 70 is approx $99-$110 street price
the Hacker Master 70-3P $157
the Schulze 70Po $252
Or the Hacker 77-3P 30 cell controller will be approx $241
Schulze 80Fo 27 cell controller is approx $378
In short the Master controllers operate at the current extremes of high performance with features, flexibility and price which make them outstanding value.
Comunque secondo me meglio alimentazione separata indipendentemente.
I.M.O.H.
.l'importante è divertirsi.
giava76 non è collegato   Rispondi citando
